Pick Up Coil Removal on '89 Iroc, 305 TPI
Old May 10, 2006 | 06:33 AM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
OK, what's the trick to getting the Pick-up coil out of the distributor? The factory shop manual says:
1) To remove pick-up coil, remove retainer and shield.
2) Lift pick-up coil assembly straight up to remove from distributor.
Sounds simple enough......but, I dont have a retainer or shield as pictured in the factory shop manual and this thing won't budge when trying to lift straight up? What am I missing here?
Anyone have a picture of the pick-up coil from their distributor from an Iroc Z so I can tell if mine is supposed to have this retainer and shield as pictured in the shop manual?
Old May 10, 2006 | 08:20 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
you have to remove the dist and then remove the gear and take the shaft out
then you can remove the pickup coil.
Old May 10, 2006 | 09:10 AM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Is it a press fit on the splines of the distributor shaft?
Old May 10, 2006 | 09:20 AM
No.
It doesn't touch the shaft. The coil sits still in the housing, while the shaft spins.
The center of the coil is below the reluctor which IS on the shaft; the little "star" thing. It cannot come out with the shaft in the way.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
