motor is locked up.
motor is locked up.
i got an 85 iroc out that had been p[arked in storage for about 8 years. of course the motor is locked up. what steps should i take to get it running? and if its just the motor, when i put power to the car, would i be able to here the starter engadge? any help would be greatly appreciated.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
pour wd 40 down each cylinder and wait a while, i would use probably a whole can for all 8 cylinders, over a series of a couple of days, eventually it should break free with a breaker bar on the crank snout bolt, just give it time at first before you really pull on it and strip out the crank threads.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Remove all the spark plugs and squirt some mystery oil in the cylinders and leave it like that for a day or two. If there is nothing mechanically wrong with it, ie spun bearings etc, this might free it up.
Car: 1984 Z28
i'd wait for the motor not to be locked up before trying the starter....wouldn't you ?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1992 Trans Am
May 10, 2023 07:19 PM
