Spring Oil Change
Old May 12, 2006 | 02:25 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
Spring Oil Change
I read somewhere that you should change your oil if your car has been sitting for a period of time, no matter how many miles it's been since the last oil change. Anyone have any insight on this? Is it true, or are they just trying to get you to buy more oil?
Thanks.
Old May 12, 2006 | 04:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Sure, why not?
Get rid of any condensation buildup and any other goodies that got in there while it sat.
It doesnt cost anything to change oil... unless you go with some fancy synthetic oil.
Old May 14, 2006 | 07:57 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
Thanks. I do use synthetic and I just changed it before parking it in the fall. I guess better safe than sorry.
Old May 14, 2006 | 10:21 PM
Vader's Avatar
If you just changed it before storage, that's a good thing. That means that there was no chance for acids to form in the oil from heat/cool cycles from starting and stopping the engine. And because of that, the engine didn't have to sit in an acid bath all winter long. You should be able to start and run the engine with no problems, and change the oil when it is due or when you store it again - Whichever comes first. I've been doing that for about 12 years now. I know that isn't much for empirical evidence, so if it doesn't work out, I'll let you know once I've tried it for a while.
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
