Help installing speedo
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
I got a 145 mph speedo and yes its the right kind for my car i have the 85 mph one i cant even get my old one out 1st thing was at the end of my steering wheel there was some wired clamp thing i had to break off even after that seems like my 85mph just dosent not want to come out i've looked and looked and i cant see any thing holding it in but the cable behide it there is no way i can un screw the cable while the speedo is in help please! thanks.
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey bro, there is like a metal clip that holds the speedometer cable in place. I don't remember how to exactly take it off but I am sure thats where you are stuck. If you do a search you should be able to find out how to take it off.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Dude if you broke something you might be screwed. First you need to remove the bezel, next there are 2 10mm bolts you need to take out that are where the light bulbs are (seat belts, brake etc) Next I find it easiest to pull down the fuse holder, stick you hand up into the dash and remove the speedo cable (unless you already broke it.) Installation is opposite of removal.
I got it in this morning thank god once i found them metal clip i got that cable off then finish it! Looks cool alot better then the 85 Mph one
ambainb
Apr 25, 2016 09:21 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
