IROC dies when I turn on A/C - Doesn't idle-up - '89 TPI - HELP
Old May 15, 2006 | 02:26 PM
Chevy Muscle's Avatar
Ok, new problem on this IROC.
The A/C works fine but when it is turned on the car will die if I don't have my foot on the gas.
It seems to me that I think that some idle control should increase the revs when the A/C is turned on...... am I right?
What should I look for to fix this?
('89 305 TPI with a 5spd)
Old May 15, 2006 | 03:27 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Interesting. Check all the vacuum hoses around the AC.
Old May 16, 2006 | 07:59 PM
any ohter ideas?
Old May 16, 2006 | 08:13 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
take it off and put a a/c delete box on thats what windows and the t-tops are for
Old May 16, 2006 | 09:25 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Make sure your idle air control is working. Then make sure it is adjusted properly.
Old May 17, 2006 | 07:39 AM
Ok, how can I check for proper adjustment?
Old May 17, 2006 | 07:50 AM
Vader's Avatar
Is this a stock PROM/MEMCAL, or is it a custom? If the PROM is stock, there should be about a 50 RPM target idle adder when the A/C is turned on, provided the ECM is getting the input. If it is a custom PROM, the tuner may have overlooked the A/C idle adder.
This all depends on having a fully functional IAC, however. There is no way to adjust the IAC. It is under constant control of the ECM. What you CAN adjust is the minimum air position of the throttle plates so the ECM can control the idle RPM properly. Try a SEARCH for "minimum air position."
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
