Oil in Distributor Cap - WTF?
Old May 16, 2006 | 09:32 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Yah, my old cap I took off when I redid the manifold gaskets and fuel regulator had the same thing. I thought it was condensation which might have been from a crack in the cap somewhere.
I replaced the cap and checked it today and it is infact oil.
The distributor was replaced when I built the engine.. Its a PROCOMP and after seeing this i'm thinking it's junk??
Opinions?
This is the buildup after 5 days...
Old May 17, 2006 | 05:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I had an older HEI dizzy that did the same thing - there's a seal down in it somewhere - but I didn't see where it was worth the trouble, when a brand new Accel brown cap dizzy can be had for $125 at Autozone, so I just got a new one of those, and it works fine - also came with adjusting springs and other goodies if I ever figure out tuning to that degree - but it does NOT come with the coil.
Old May 18, 2006 | 02:33 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
What kind of crankcase breathing system do you have? and what is the max RPM that you run to. Too much crankcase pressure in high RPM can force oil up your shaft also.
Old May 18, 2006 | 09:48 AM
Stock PCV system.
6,000rpm.
Old May 18, 2006 | 09:57 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Might want to try an open system W/breather caps on the valve covers.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
777Shock777
Oct 29, 2015 04:30 PM
86IROC112
Aug 17, 2015 07:57 PM
Out-Cast
Aug 17, 2015 10:57 AM
