Code 32
Old May 17, 2006 | 07:22 AM
Gammohr's Avatar
Code 32
I have been getting a code 32 for quite some time now. This means the egr system is failing. What I need to know is how does the ecm determine that the egr system is bad? What sensor sends info to the ecm indicating that the egr system isn't working?
88 camaro 305 TBI
Old May 17, 2006 | 12:16 PM
nameinuse's Avatar
The MAP sensor is expecting a change of manifold pressure within a certain amount of time after an EGR command,I think.
Old May 18, 2006 | 12:59 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Your EGR valve may be stuck partially open
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
