Newb posts again
Old May 17, 2006 | 10:33 AM
ggb42069's Avatar
Newb posts again
I just got an 89 transam (5.7) litre for FREE. I got it run and did a tune up on it, plugs, wires, cap, rotor, fuel filter, oil, tranny fluid, pcv valves, and cleaned the K&N filter on it. I was wondering what else you guys would reccomend. I was thinkking that i would do the timing on it (what are the specs)? I also want to check the tps (How)? Please shed some light on this subject, because i am not used to fuel injected cars i usually play with carburated cars so any help would be appreciated, i want to get this car running good in stock form so that the BUILD UP CAN BEGIN!!!
Old May 17, 2006 | 12:29 PM
nameinuse's Avatar
Originally Posted by ggb42069
pcv valves
Should be just one.My van had two,one in each valve cover,when I bought it.
Took me a while to figure out what looked so wrong.
Old May 17, 2006 | 12:45 PM
ggb42069's Avatar
Which side is it supposed to be on? and what goes in the hole on the valve cover? Mine has 2. And there are lines to hook them both up and holes on both valve covers.
Old May 17, 2006 | 01:08 PM
nameinuse's Avatar
Any side will do,the line with the valve is connected to to manifold vacuum and the other side goes to the air cleaner (in my case to the spacer ring between the tb and the aircleaner).
I simply gutted one of the PCV valves and used it to connect the breather hose to the valve cover,guess that works until the motor develops more blowby.
Old May 17, 2006 | 02:40 PM
ggb42069's Avatar
but my car has tpi.
Old May 17, 2006 | 03:05 PM
nameinuse's Avatar
Never fiddled with a tpi motor,but the hose without a valve should be taking in air through the air filter,or vent gases that way when vacuum is low and crankcase pressure is high.
That hose should be plugged in somewhere between the air filter and the throttle blades if the principle is the same as on my tbi motor.
Old May 17, 2006 | 08:06 PM
ggb42069's Avatar
alright i am thinking it is the one the goes to the throttlebody then.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
Strick1
Sep 6, 2015 02:21 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
