yanking out motor
Old May 17, 2006 | 04:23 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
yanking out motor
Im about to paint my car and im pulling out the engine so i can paint the engine bay because its a complete color change. i was just wondering how hard is it to pull a carbed automatic 350 out of a 89 Rs? i have a haynes manuel and it doesnt sound to hard but i have never done it before. also i know i have a manual but what all do i need to pull from the engine. i already pulled the hood and driveshaft off earlier today.Is this a all day chore or more like a week long chore? i took auto-tech I and II in high school where we pulled engines out of FWD cars like hondas but i havent done anything like this before but i think/hope i can do this.
Old May 17, 2006 | 04:38 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
it should all be done properly with in 1hr
Old May 17, 2006 | 05:31 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Prior to taking the engine out, make sure to take plenty of pictures of all the wires, sensors, plugs, etc. This will help when you put everything back on the engine. Are you planning to remove the engine and tranny together? If not, you will need long extension to reach the upper part of the engine/tranny bolt. Although I have seen people install engine with the readiator in place, I would have it removed. Since you have some background in removing engines, even if it's fwd, you should be able to do it in less than 2-4 hours and that is doing the work yourself.
Old May 17, 2006 | 05:52 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Pulled my junk 350 last night (water in #6 hole).
Took about 2hrs to do taking my sweet a$$ time (including the beer breaks). The hardest part was trying to get them dang bolts out of the headers...
Pretty simple job.
Old May 17, 2006 | 07:20 PM
redfbody91's Avatar
Car: 91 camaro
Engine: 3.1
Not long at all helps too have a buddy's extra hands around. Listen to above make sure you label wires and sensors and make sure you disconnect all grounds and pull it out slow to ensure you got everything.
When you get done you will be like dam, thats it.
J
Old May 17, 2006 | 07:30 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
thanxs for the help
thanxs for all the replies. yea i just got done taking the radiator out and need to run to the store to get film for the camera (dont have digi cam ) i know i could always count on your guys. i have been surfing this site for the longset just looking at others post and staying in the shadows. and i knew if i ever needed help with anything this would be the place to come.
Old May 18, 2006 | 03:06 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I will be doing this soon too to swap it into a hopefully nicer body... good luck.
Is taking it out with the tranny much harder? (t5) I couldnt imagine so...
Old May 18, 2006 | 04:17 PM
redfbody91's Avatar
Car: 91 camaro
Engine: 3.1
I think it makes it alot easier to remove them as a unit
Old May 18, 2006 | 04:26 PM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Definately easier to pull them both at same time. I've had to do it twice in the past year.
Old May 18, 2006 | 05:13 PM
TheWesman's Avatar
I took my engine out last week for the first time. It took me a total of 6 hours + 2 six packs from a running car to having the engine hanging on an engine stand.
A few tips.
1) Jack the car up and set the frame rails of the body on jack stands. don't rest the jack stands on the rear axle.
2) My car has a manual transmission so I pulled it from the bell housing before pulling the engine. Rest the back oil pan on something first.
3) Remove the window wiper motor.
4) make sure your engine hoist is setup to pull the motor out high enough but can still do it without hitting the roof of your garage.
5) I pulled my engine with the bellhousing and engine accessories all attached. i.e. Power steering pump, Air Compressor, etc...
6) pull the engine up off the motor mounts a few inches and pull it forward to make accessing the rear of the engine block easier so you can remove the wireharness.
TheWesman
Oh I forgot, remove the hood at the fenders and not at the bracket/hood spot.
Old Feb 13, 2007 | 05:26 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Where exactly do you attach the chain anyway ?
I've seen some people attach it all to the intake manifold ? With an adaptor plate ?
Old Feb 13, 2007 | 08:37 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I normally just pull 2 intake bolts out and bolt the chain up with 2 longer grade 8 bolts with some thick washers.. I've used one of those plates that bolts on in place of your carb before too, I've heard its not a good idea on an aluminum manifold because it can elongate threads in the holes or strip em out thus dropping the engine which makes sense but I had no problem with it.. there's many other options though, I'm sure others will chime in..
Old Feb 13, 2007 | 08:47 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmm ok, because after reading a bunch of posts, I changed my mind and decided to remove the engine with the tranny, original plan was just the engine but it seems so much easier to pull both, my question is just where to attach the chain
hmmmm
Old Feb 13, 2007 | 09:24 PM
89RsPower!'s Avatar
I'm confused.. I know I'm a little drunk but isnt that what I was talkin about?
Old Feb 13, 2007 | 10:09 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Is that the only place one can/should attach the chain to ?
ktthecarguy
Jul 5, 2020 11:46 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
hydrolic144
Sep 8, 2015 06:55 PM
sunbound
Sep 5, 2015 11:52 AM
C409
Sep 1, 2015 03:42 PM
