I guess I was running too much timing... (pics)
Old May 17, 2006 | 09:52 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I took apart the engine yesterday and I discovered that all of my upper halves of the rod bearings were fubar, and the mains were pretty bad too... Also, when I pulled the pistons out, the top compression rings came out in multiple pieces... My teacher said it's definitely a problem with detonation, and the first thing that came to mind was that I was running the weakest springs on my distributor for the sharpest advance curve. But everything else looks fine, and will be re-used. I'm building a different motor to go back into the car though
Old May 18, 2006 | 02:08 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Probably didn't do the top ring grove any good either. How many miles did you have on it?
Old May 18, 2006 | 02:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why is he so sure it's detonation? You'd think you would have noticed something was wrong a lot sooner if it was detonating that badly.
Old May 18, 2006 | 07:13 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Those who can't do, teach.
What exactly is wrong with these parts? They look like every other motor i've taken apart with 100k on it.
Wanna see some detonation pix, you should see my old 355 when it blew up at 6500rpm @ 12psi boost.
-- Joe
Old May 18, 2006 | 10:55 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, not something you want to hone and rering with new bearings eh? Well if you've already got your heart set on a new motor, no reason not to continue on that path...
Old May 18, 2006 | 01:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Have you got pictures of the broken ends of the rings? What gap were you running?
Old May 18, 2006 | 11:51 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
STOCK BOTTOM END!!! lol
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Street Lethal
Aug 13, 2015 08:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
