who has a built 700r4 and does it make noise?
Old May 18, 2006 | 01:52 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
so i have a fully built 700r4 and i have not had lockup for over a year now...i have a huge cooler tho so it should be ok intell i find out why im not gettin lokcup.....anyways my question is does your tranny make wining noises like a blower/gear drive..ect not when im in P or N but when i put her into D she sure starts to wine and its louder at low rpms the higher you go low lower the noise intell it shifts into 2nt then it will get louder intell higher rpms....anyways just wanted to know if this is normal on a built 700r4 or should i be lookin into it more? i think it sounds good but not sure if it is good!!
Old May 18, 2006 | 02:20 AM
IROZINCO's Avatar
700r4 making noise
I have a built 700-r4 - non-locking TQ - it does not make any noise at all. Yours sounds more like the rear-end making noise.
Old May 18, 2006 | 02:33 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
My prepped T56 did that..."gear whine" if you will - pretty cool noise, actually. Not sure if that's any help to you, though. Never had a prepped 700.
Old May 18, 2006 | 06:05 PM
Car: 92 1500p\u 2wd
IROZINCO---what does it have in it? cus mine sure has "gear whine".......
Old May 18, 2006 | 06:19 PM
Car: 92 1500p\u 2wd
ok this is what the trans has in it..update 3/4clutch pack...wide 700r4band..forward sprag...low-reverse sprag-wide...HD sun gear shell..large servo kit..throttle valve -boost valve..HD shidt kit....this was all put in when i got it built...then i put a b&m 2200-holeshot lockup in it...i have looked back the paper work from summit and it is a lockup tc. so with that said anyone else have input?
Old Nov 16, 2016 | 12:47 AM
WG383's Avatar
Car: 1988 Camaro
Engine: 383
Re: who has a built 700r4 and does it make noise?
i have a new built and it wines did you ever find out what was going on or is this normal? i know this is an old post but please if you found the problem
thanks
theshackle
Sep 17, 2020 08:26 AM
camaro11j
Sep 19, 2018 08:49 AM
B_Dubya
Aug 26, 2015 05:09 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
