Big problem
Old May 21, 2006 | 02:23 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Big problem
I'm installing my small block and I've got a problem. One of the motor mount bolts is broken off in the motor (not my fault, guy who had the motor before). First I tried to easy out it. The tip of the ****ing easy out broke off inside the bolt. Then I tried to drill with a tiny bit right next to it and that damn bit also broke off. I'm extremely frustrated right now someone please shoot me some tips. The easy out is made of hardened steel which makes it impossible to drill without chewing up my bits. I feel so ****ing retarded right now.. doh.
Old May 21, 2006 | 04:16 PM
skid305's Avatar
Car: '89 Bastard RS
Engine: 310 TBI
Transmission: 700 R4
Axle/Gears: 3.23 Posi
That's always a good time. Maybe heating it up and a left handed drill bit?
Old May 21, 2006 | 05:16 PM
Engine: 400
I've heated it up and the surrounding "humped" area and also sprayed it numerous times with the best PB blaster stuff (tapping the area with a hammer) the hardware store carried. It was like 12 bucks a bottle and is made for loosening bolts.
The bolt is flush with the block. I'm wondering if I can weld on top of the bolt until I get a good surface, grind it down to fit a wrench and then turn it off? I would immagine the bolt is pretty loose (especially if I heat it 5 or 6 more times and use a **** load of the bolt lube ****), I just have no way of really getting a handle on it and turning it out.
-Greg
Old May 21, 2006 | 07:02 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Your on the right track. Take a 1/2" nut and hold it over the broken bolt or better yet have someone hold it there with pliers. Now take your welding rod and go through the nut and weld the broken bolt to the nut. Don't be shy here, you need to get a good bite. Now take a wrench and start to wiggle the bolt back and forth, slowly removing it from the hole. Take your time here. If you try to just back it right out it will usually break off. Trust me, this method works, I've used it dozens of times.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
