Engine hesitates after headers
Old May 22, 2006 | 10:11 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I recently installed Hedman Shorty headers. Along with them I installed new plugs and wires. I gapped the plugs to .045 (as stated under the hood). Whenever I give it WOT the car bogs/hesitates then after about a full seconds will get moving. It also feels less responsive at part throttle. What could the problem be? Is the .045 gap to big? Thanks
Old May 22, 2006 | 10:15 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by Frozer!!!
Is the .945 gap to big? Thanks
Thats a hell of a gap.
Old May 22, 2006 | 11:22 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
HAHA yes it is! I meant .045 lol
Old May 22, 2006 | 11:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You've effectively leaned out the mixture. You can crutch it a little by advancing the base timing a bit.
After that, though, you need to richen it up, mainly in the secondaries. Richer rods will most likely help a lot. You also need to adjust the secondary air valve tension - and make sure your choke pull-off is working while you're at it.
Old May 23, 2006 | 12:47 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Thank you
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
