Rusty ligter bores.
Old May 20, 2006 | 07:52 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Rusty ligter bores.
Is there a way to clean rust out of lifter bores if its not potted to bad.
Old May 20, 2006 | 08:23 PM
ede's Avatar
ede
bare block? a brake hone works great other wise i'd spin a brass brush in a drill.
Old May 20, 2006 | 11:59 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Naval jelly eats rust without changing the diameter of the lifter bore.
Old May 21, 2006 | 09:28 PM
stroker_SS's Avatar
Engine: 355
Where could i get some of theis naval jelly you speak of?
Old May 21, 2006 | 09:30 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
we have a lifter hone at school, try one of those
Old May 21, 2006 | 09:35 PM
stroker_SS's Avatar
Engine: 355
I'm going to need more than just a lifter hone to clean this block up and thought any thing less than an acid bath wouldn't clean it up. However i never even thought of naval jelly for the rest of the block.
Old May 22, 2006 | 12:22 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Just about any auto parts store should have it.
Old May 22, 2006 | 02:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hot tanking wouldn't cure that eh? how much is an acid bath?
naval jelly is about $3-4 a can, good stuff, it's thick. It's basically a phosphoric acid jelly, autobody places will have similar stuff in a liquid and gel form, Rust-Mort comes to mind.
Old May 22, 2006 | 09:12 PM
stroker_SS's Avatar
Engine: 355
Bought some permatex naval jelly today, so we'll see how it works out. Smelled pretty good, kinda like cherry or something, and then i read that it may cause respiritory irritation and got me thinkin why theyd make it smell so good, oh well.
Old May 23, 2006 | 12:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hot tanks use alkaline lye which is good for oil and grease, but it takes an acid to do anything to rust.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
aaron7
Sep 30, 2015 09:15 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
RyanJB
Sep 14, 2015 03:39 PM
