Camshaft Replacement?? engine in or out??
Old May 23, 2006 | 11:17 PM
cam383rs's Avatar
Car: 92 Camaro RS Z Clone
Engine: 350TPI
Transmission: 5 Speed
Hi All,
Just found out I've got 2 exhaust lobes wiped on my cam..(a face thats crying would be great here). I am seeking advise from anyone who can offer it. Has anyone swapped a cam with the motor in the car, or is it a must to come out on our cars? I really really am not looking to have to pull the motor again. Any help or ideas would be great...Thanks.
Old May 23, 2006 | 11:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you've got wiped lobes it should come out so you can inspect for any other damage.
Old May 24, 2006 | 12:00 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I agree, if you just change the cam/lifters, you're betting on the fact that the fil;ter has all the cam material in it.
If it's just a low budget motor you're playing with, fine, but if you have any real dollars inside, best to pull it out and see what it looks like.
Old May 24, 2006 | 01:04 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I just did a cam/heads swap in the car. Pull it!!!!
Old May 24, 2006 | 07:48 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
It can be done in the car.
Its easier out of the car obvioulsy.
If u have damage like u said, I would recommend pulling it so you can inspect everything.
later
Jeremy
Old May 26, 2006 | 11:01 PM
cam383rs's Avatar
Engine: 350TPI
I am really confused now????????? Theres no metal anywhere and we pulled the valve cover and the valves are moving exactly as they should. The problem I am having is number 3 and 5 header tubes are not heating up, you can grab them by hand after its been running for 20 minutes. I have spark so we thought maybe fuel..its a TPI, so I pulled the injectors blew everything out with air and swapped the injectors. They are now heating up to where you can't grab them, so I am lost. I am going to drive it around the block Saturday and then hit it with a temp reader and see if the temp is the same on all pipes, cross my fingers, if not I am right back where I started.
As far as the swap one of my customers (an automotive shop) said he'd stab one in for $400.00, so I'd let him fuss with it this go round rather than me. Any input or ideas would be appreciated.
Old May 30, 2006 | 10:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Might want to readjust the valves?
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
