Idle with this came
Old May 24, 2006 | 07:04 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
Idle with this came
I bought a Lunati Cam part number 00010LK
Just curious at how the idle will be on this? 2000-6000 is the power range. Thanks
Old May 24, 2006 | 09:26 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Has a moderate rough idle with reduced intake manifold vacuum at idle.
You'll want to recurve the distributor for more initial timing at idle, but same 34-36deg at high rpm. (limit mechanical advance travel from 20 to about 12-16)
allowing 20 to 24 deg at idle.
Power brakes should work ok. If you have trouble with them add a vacuum reseviour canistor. (increased capacity) Needs more than stock compression ratio 10:1 best 8.5:1 will not cut it.
will work just ok with a stock converter (2100 stall) {you'll get by} but don't expect to be set in your seat.
really needs a 3500stall. 3.73 minimum gears. 4.10's best ,,needs headers and dual exhaust.
head porting will definatly help. use a vic JR or Perf RPM and 750cfm carb.
If you don;t have close to these other parts you probabily picked the wrong cam. use lunati #73943 springs.
Can work very well for ya if combined with the rest of the
recipe.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
