starter shimming
Old May 24, 2006 | 10:42 PM
BanditMan's Avatar
Car: 84 trans am
Engine: 305 H.O. with small cam
Transmission: th350 with manual valvebody
Axle/Gears: 3:73's
starter shimming
I searched for this and turned up 300+ results, so i thought it might be easier like this. First off all, It seems like the battery, cuz unless I use my brothers jump pack when i try and start it it wont fire, it will turn over slowly, and eventually just stop and make a grinding sound or do nothing at all. I replaced my hot wire going to the starter and checked all the wires, just fine. Tightened all connections and even put on a heat wrap to prevent heat soak. Ive read a lot about having to shim these starters. When i took mine off, there was none on it. So ive ruled it down to a bad solenoid, maybe a bad battery, but most suspectively, the alignment off the teeth meshing. When they say shim it does mean to put shims between the block and the starter right? Cuz i dont see how you could shim it fore and aft. Thanks yall, and i really hope to solve this as it is really anoying.
Old May 24, 2006 | 10:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
shimming is only used if the gear meshing creates a grinding sound....typically they're not used at all in stock applications. i would suspect a bad battery ....go have it tested first off, and have the starter tested secondly if the battery fails.
Old May 28, 2006 | 10:43 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
Took the battery to orielys and had it tested. It was gone. Bought a new one, now it starts like it aint never started before. A one second hit on the key and she purrs now.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
