Problem with 88 305 TBI
Old May 25, 2006 | 04:47 PM
hoss1059's Avatar
Finally got my sons car converted back from carb to TBI (idiot before me). Replaced the intake and distributor and rebuilt the TBI. Purrs like a kitten and can drive it around. Once it reaches operating temperature and then you shut off the car, it won't start back up. It will turn over, it has spark and fuel, just won't start. Timing issues? Don't have a timing light at the moment to check.
Tony
Old May 25, 2006 | 05:48 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Are you throwing any codes?
Old May 25, 2006 | 07:55 PM
hoss1059's Avatar
Yeah, I'm throwing a 33 - MAP sensor and a 42 EST. Is 42 the distributor? I found one reference in my Chilton's about EST distributor. Timing perhaps?
Old May 25, 2006 | 09:04 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
As far as the code 33 it is saying that the MAP or manifold absolute pressure is higher than normal. It could be many things.
A.)Faulty MAP sensor
B.)Vacuum leak
C.)No vacuum connection to the MAP
D.)Wiring fault
To troubleshoot I start by taking my DMM, select the 0-10 volt scale, backprobe the center wire in the MAP connector. Now with the KOEO read the voltage. It should be somewhere between 4.5 to 5 volts. Now start the engine. It should drop to somewhere between 0.8 and 1.5 volts. Now play with the throttle, when you open the throttle it should go up, when you close it, it will go down, then return back to the idle reading. Disconnect the vacuum hose from the MAP and it should stall.
Code 42 is an ESC failure. It could be several things as well.
A.)Bad knock sensor
B.)Bad ESC module
C.)Bad connection in the wiring
D.)Faulty ECM
Old May 26, 2006 | 08:47 AM
hoss1059's Avatar
Thanks, I was wondering how to test the MAP because the Chilton's I have doesn't state how to. Appreciate the help a bunch.
Tony
Old May 26, 2006 | 08:46 PM
Ravyn's Avatar
Car: 1988 camaro
Engine: 305, 5.0L TBI
Transmission: 700R4 auto
A friends car did the same thing, run around fine and then once shut off, wouldn't start again. The problem turned out to be it needed a heat shield on the starter... the starter would get to hot and after putting the shield on, it solved the problem. It ran just fine after that! Hope this might help, aside from all the codes and any other problem you're having!! Good luck!
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
