psi to compression ratio
Old May 26, 2006 | 05:09 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
i have 160 cold psi what would that be in compression ratio
also several of my plugs were oily when i changed them that is why i did the compression test. 160 psi would be a good signal that the rings are good and it is my valve seals that are bad.
Old May 26, 2006 | 05:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It could be anything...
CR is calculated with piston dome/dish size, bore size, headgasket thickness and bore and last but not least combustion chamber size.
Old May 26, 2006 | 05:29 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
cranking compression can change depending on a lot of things
take two motors both with 10:1 compression one with smaller heads, smaller cam and so forth. might have a cranking psi of around 200plus
take the same 10:1 compression motor with a huge cam huge heads all full race setup. might pull cranking compression of 150-160psi
Old May 26, 2006 | 05:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it's the variation between cylinders that you care about. all within 10psi of 160psi ? you're good.
yep, swap out them valve seals first, it's easiest.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
