Engine Question
Old May 26, 2006 | 07:04 PM
Pizzle's Avatar
Engine Question
Hey first post
I have a question about this engine. I am potentially buying an 88 Camaro and seems like a good deal. The guy I may be buying the car from says that it runs smooth, however there is a slight ticking from the top of the motor.
Was wondering what you guys might think it is? Might be a stupid question, and may be nothing, but I want to be positive before I invest.
Old May 26, 2006 | 07:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hopefully it's normal injector ticking. Otherwise it could be valvetrain noise.
Old May 26, 2006 | 07:27 PM
Pizzle's Avatar
yeah, my luck it would be something with the valve train being off. thanks for the fast reply
Old May 26, 2006 | 07:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its pretty common for people to hear the injectors at idle and go off the wall thinking its a bearing or lifter.
Does the ticking seem to go away when you bring the RPMs up?
If the noise gets louder and speeds up its most likely a misadjusted rocker.
Good luck on your possible new purchase!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
