motor swap..
Old May 27, 2006 | 06:21 AM
xdamxincx's Avatar
motor swap..
i put a mildly high performance 350 sbc carb'd motor in a 305 tbi car.its a 87 caprice .but i think still same motor as whats in the 3rd gens.. but anyway..
i read the section on tbi to carb swap..
now it states, i think,,, that i have to use and aftermarket distributor or an older distrubitor from 74-83.. but i used the stock distributor and it is working.. initial timing is 25... and total timing is 37... car starts fine runs fine....
not sure what i am asking but is this possible.. it was 4am when i finally got done with the car....
some people run cars totally locked out at 38 ,,, so i just want to re assure myself that this friend of mine car is gunna be ok...
Old May 27, 2006 | 11:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If theres no ECM, then pull the stock dist. out. Theres some advance built in due to amplitude increases with speed in the signal from the pickup coil, but its not very much, and theres also no vacuum advance like youd have with a standard HEI.
Old May 28, 2006 | 01:18 AM
xdamxincx's Avatar
i really am not following what you are recommending.
you want me to pull the dist out ?
if that is correct . i am asking y ?
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
