new heads and cam
Old May 29, 2006 | 05:57 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
new heads and cam
I have just installed new heads and a new cam in my 350. my car had more power with the old cam that had a couple of rounded lobes. I don 't understand this. the timing is close. I just don't have the accelleration that I had with the old cam. also my car is heating up alot. i took it out for about a mile or two and in that time i was up to 250 or 260 on my just installed temp gauge. I am out of ideas. I did bleed the cooling system. I was wondering what would happen if i was one tooth off on the timing chain. I know that I had it lined up correct but I am now questioning what would happen if it was off one. it is frustrating. thanks for any help.
Old May 30, 2006 | 08:50 AM
B Rhodes's Avatar
Car: 91 B4C
check everything that is different now than it was. might be a timing gear a tooth off or wires in wrong order, possible valvetrain mis adjustment with new heads also. Good luck. I would check and recheck the easier stuff first before checking the timing chain alignment.
Old May 30, 2006 | 08:54 AM
Identifying the 2 cams might help.
Sounds to me like you have an assembly problem, if the cam is not a GROSS mismatch to the rest of the combo.
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
