egr control solenoid location
Old May 31, 2006 | 07:43 PM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
searched the board
so now i need your
looking for the location for the egr control solenoid on a 91 L-98
also any help finding out why my Nox is so HIGH 1435 when max is 767 that like double HC and CO are good so im assuming cats are good right???
just replaced egr valve yesterday so next is the solenoid with your help thanks guys
Old Jun 1, 2006 | 07:51 AM
Scotty27's Avatar
Car: 1989 IROC
Transmission: t5, wanna be a t56 when I grow up!
Axle/Gears: Whatever stays bolted on behind me!
From the info you posted, I'd say cats are fine. High NOx is def. EGR related. The solenoid should be in the same rough vicinity as your egr valve. You should also check that egr temp sensor (my wire was snapped) and any vac lines while you have the plenum off. Those vac lines get mighty brittle over the years...
Hope that helps!!!
(BTW, high NOx is caused by combustion temps that are too hot. not to be confused with general water temp)
Old Jun 1, 2006 | 08:46 AM
Vader's Avatar
Look to the right of the distributor:
Old Jun 2, 2006 | 01:04 AM
thanks for the NOx help
to the right of the distributor?, the upper right hand corner is the fuel presure regulator??? or am i wrong
thanks for the pic buy the way, did you relocate the coil???
Old Jun 2, 2006 | 04:28 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
Yes that is the pressure regulator it has a vac line connecting to the plenum you see it clearly in the picture,you can rebuild the regulator to a adjustable type with the right tools/parts.
Rgds Mats
Old Jun 2, 2006 | 06:42 AM
Vader's Avatar
That's an older TPI - Coil in the cap. The EGR solenoid is the black rectangle next to and below the distributor. There are gray and black plastic vacuum lines connected to it. Removed, it looks like this:
Ghettobird52
Jul 5, 2024 11:18 PM
jklein337
Sep 19, 2018 06:23 PM
Out-Cast
Sep 3, 2015 09:05 PM
injdinjn
Aug 28, 2015 12:51 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
