runs then dies
Old May 31, 2006 | 09:40 PM
larrywHawaii's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: automatic
runs then dies
Aloha,
Maybe someone can help me out there. I have a 1989 2.8 litre mutiport fuel injected v6, The problem is it will run sometimes for a little while the just dies off. I put a new fuel pump, fuel filter, checked the injectors,checked the pressure regulator, checked for vaccum leaks, no moisture in the distributor, new wires, new plugs,new aircleaner. Very clean engine and replaced the head gasket and did a valve job about 3000 miles ago. I thought I was a pretty good mechanic but this one has got me stumped. Help!! Please
Mahalo, {Thank You}
LarryWHawaii
Old Jun 1, 2006 | 08:52 AM
Vader's Avatar
Welcome Aboard!
You've done all the work to the fuel delivery system, but neglected to list the standing fuel pressure (while running).
And just to help us a bit, how long is "a little while" before it dies?
Old Jun 1, 2006 | 09:49 AM
Car: 89 firebird
Engine: 2.8
Aloha,
I haven't checked the pressure in pounds but judging by the way the gas spurts out from the pressure valve I say it's enough. It will run for about a minute, I can rev her up to about 4 grand then she just dies off. I also replaced the ecm, and Iac valve. I'll get a pressure gauge and see how many pounds it auctually is.
Mahalo, Larry
eightsixseven
Dec 16, 2024 01:50 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
