backfiring
Old Jun 1, 2006 | 11:20 PM
25th rs camaro's Avatar
Car: 1992 Camaro Rally Sport
Engine: L03 305 E TBI
Transmission: M5
Axle/Gears: 3.08
backfiring
Hi i have 92 RS L03 TBI and it seems to have a problem with backfiring and surging when under reasonable thorotle. Ive changed plugs, wires, dizzy cap, ecm, both fuel injectors, fuel pressure regulator,02 sensor and some other suff i cant think of at the moment. And when its cold i have to press down the throttle to start it and keep it running this is only when its cold but when its warmed up it idles at 700 but still surges backfires. The timing is set to 4*BTDC. I have no clue what to do next i thought it was something to do with the fuel but apperantly not? And also sometimes the check engine light will go on but then turn off a few moments later when its on its throwing the 02 sensor code which boggles me because it has a brand new 02 sensor on it...
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
