weird problem ???
Old Jun 2, 2006 | 07:11 PM
1blakGTA's Avatar
weird problem ???
Decided to take my 89 GTA 350tpi for a spin after 3 weeks of sitting in the garage. But when i put my foot onto the gas the car struggles to move, sometimes even backfires and it does this at idle and at all tempertures.
I checked for codes but nothing came up. I found if I slowly lean the power on its fine, but when I plant it to the floor it surges, struggles, and carrys on.
The ignition coil is 2 months old and the distributer is 18 months old. Is it possible to be one of these two at fault or should I be looking at something else,,,,,,,,
Any help would be greatly appreciated,,,,,starting to get a little frustrated !!
Old Jun 2, 2006 | 07:21 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Blak,
I also have a 350 TPI, but in an 87 IROC. I had a very similer problem after my car sat. It was doing the exact same thing. Now I doubt that you will find this as your problem but it couldn't hurt to check. While my car was immobile, my brother "borrowed" a fuse from my fuse block that happenned to be one of my fuel injector fuses. When I replaced the fuse the car ran great, no more problems. Hope this actually helps. Good luck.
Old Jun 2, 2006 | 10:27 PM
1blakGTA's Avatar
I checked the injector fuses and changed them anyway,,,,,,,,no change,,,,,,,,,any other ideas???????
Old Jun 3, 2006 | 12:38 PM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
new spark plugs? maybe went bad after sitting .. mine did, it sat for a few months and done the same thing...mines carbed though
Old Jun 4, 2006 | 02:35 AM
Super_GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
There are still quite a few things to check before you can narrow this down. I would start with fuel delivery. Find a fuel pressure gauge and check your fuel pressure, at idle and when your problem occurs. Water in the gas can be a problem as well. Most people prep the car to sit by putting a fuel stabilizer in it. The fuel can break down over time. You can try a can of Heet from the parts store and see if that helps.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
