IAC Adjustment engine hot or cold?
Old Jun 2, 2006 | 07:19 PM
92Z's Avatar
92Z
Just wondering should the IAC (min. air) be adjusted with the engine hot or cold? Thanks
Old Jun 2, 2006 | 07:30 PM
blackbeastRS's Avatar
Car: 1991 Camaro RS
Engine: LHO 3.1 V6
I'd say it'd be better to adjust it while the engine's at operating temperature. Considering that some motors don't really idle smoothly until they've warmed up.
Old Jun 2, 2006 | 07:33 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
The minimum idle air rate should be adjusted with the engine at normal operating temperature. Keep in mind that I'm used to working with a 5.7 TPI, but that is still a pretty standard procedure for any engine.
Old Jun 2, 2006 | 07:37 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Does not matter but if you are going to adjust your TPS/ idle screw then you will need to have it at operating temp.
specialized
Jun 18, 2022 09:26 AM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
