serp belt length
Old Jun 4, 2006 | 11:44 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
serp belt length
alrighty guys im sure this has been posted somewhere else but i couldnt find it. but here we go. Ive got an 88 Serp setup with all the acsessories. i have no need for the air pump to be there so i wanna get rid of it. has anyone done this and if you have can you tell me which belt you used to make up for the difference in it not being there? i figure its gonna have to be about 3 to 4 inches shorter but im not sure. thanx in advance guys.
Old Jun 4, 2006 | 12:46 PM
precise86's Avatar
Car: 92 RS 25th Anniv
Engine: 305, V8, 5.0
Transmission: auto aka 700R4
Axle/Gears: 3.73 rwd
is this what ur loking for: https://www.thirdgen.org/serpentine
if u read the article it says that there are underdrive pulleys installed.
Old Jun 4, 2006 | 02:32 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
"You will however need a longer belt, I used Dayco 968K6 belt. It is basically a 96.8" 6 rib belt. All parts stores stock just about every length of belt in every width. They should be able to find it using these numbers."
That's the quote from the article. I used that belt when I removed the smog pump and it worked fine with my stock pulleys.
The second diagram in that picture is the routing you should follow.
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
2012sergen11
Oct 13, 2015 07:38 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
