speedometer not working need VSS?
Old Jun 5, 2006 | 08:40 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I converted my 92 TBI 305 automatic to a 92 TPI 350 with a manual transmission. What is the correct vehicle speed sensor to buy?
Can some one help me find the correct GM part number. I bought a VSS at AdvanceAutoParts and it doesn't work.
Old Jun 5, 2006 | 11:24 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
What transmission do you have? Don't forget a messed up VSS signal will also mess up the injector circuit (the ECM needs the right pulse for both the speedometer and the EFI) I used a 1994 F-body T-56 6-Speed and a 1992 ECM, I used a Dakota Digital SGI-5 unit to correct the pulses as the ECM needs to see 4K pulse....it has various hi/lo inputs and outputs. The late model T56 has a 40 pulse per driveshaft revolution VSS signal generator.
This has to get converted to a 4000 pulse per mile signal for your VSS circuits.
Old Jun 6, 2006 | 09:24 AM
I have an 88 t5 transmission with a 92 electronic VSS. As far As I know the pulses are getting to the ecm, but somehow, not to the dash. Also, my oil pressure gauge is pegging from the time I turn the key forward (it used to work with the stock engine harness)
I found in a search that I should check the C100, but I don't know how it SHOULD be pinned.
Also, my engine harness was from a Transam. I have a Camaro.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
ChevyZ71
Aug 13, 2015 07:30 AM
mizz0313
Aug 12, 2015 06:45 AM
marcusaw
Aug 10, 2015 08:13 AM
