Need specs for cam 96 WS6?
Old Jun 5, 2006 | 12:34 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I bought a cam at a swap meet for 20.00. The guy says it is out of a 96 WS6. Toward the back of shaft is some stamping around the cam, GMP-IBC-15-705.
I would like to use it in a TPI if it is any better.
Anyone know the specs?
Old Jun 5, 2006 | 01:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
should be this,
200/207 .447/.459 117lsa
Old Jun 5, 2006 | 01:09 PM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Is that with 1.5 rockers or 1.6? Do you know?
Old Jun 5, 2006 | 01:30 PM
It's a factory cam.
The factory only used 1.5 *theoretical* rockers.
Old Jun 5, 2006 | 04:51 PM
Zepher's Avatar
1.5, like mentioned above.
Old Jun 5, 2006 | 04:55 PM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Thanks guys. That's a little bigger than stock L98. It should help a little.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
