code 43
Old Jun 10, 2006 | 10:21 PM
DMcRacer's Avatar
Car: 35th Ann. SS
Transmission: 4l60E
Axle/Gears: 3:42
code 43
Anyone know what causes this and how to solve it ?
43. Low voltage at electronic spark timing circuit
Old Jun 10, 2006 | 11:44 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
thats a knock sensor code. it signals any spark knock and tells the computer what to do w/ the timing( advace/retard) Official repair method: "Check wiring and connectors form the knock sensor to the ESC controller or ECM for an open or short to ground; if necessary, reroute the harness away from other wires suck as spark plugs, etc. Replace the knock sensor"
Old Jun 11, 2006 | 01:46 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Suck as sparks plugs huh? Heard that one more then once! Hey, could be the ESC module too. Worst case, bad ECM. I'm just quoting the book.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
