Having problems starting after rebuild
Old Jun 10, 2006 | 11:53 PM
'89 Iroc's Avatar
I just got my engine back together and it dont want to fire off. It acts like it isnt getting any fuel or something. It aint dragging or anything when I turn it over just wont start. Any tips for starting one for the first time after rebuild? Man, I am tired of working on this thing I'm ready to ride!!! Thanks in advance!
Old Jun 11, 2006 | 01:24 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Did you have the engine at TDC and the rotor pointing towards #1 spark plug when you installed the distributor?
Old Jun 11, 2006 | 01:37 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
well, start simple.
You need 3 things to have a running engine.
Fuel
Spark
Compression
Pull the #1 plug. Is it wet/dry? that will tell you if your getting fuel
Now hook the wire back to the plug and lay it on the closest ground point and have someone crank the motor. does it spark?
So if you get the wacky combination of wet plug with spark check your compression.
Other than that it should be straight forward. No gas, check fuel press. no spark check wiring, ect...
Old Jun 11, 2006 | 04:01 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
check and see if you have a good ground.. about the spark.. also check if your plug wires are in the right order.. make sure your spark is firing on the compression stroke and not the exhaust..
Old Jun 12, 2006 | 01:58 AM
'89 Iroc's Avatar
got it started timing was just a little off, Thanks
Glowsock
Jul 24, 2025 03:15 PM
hectre13
Dec 11, 2023 08:14 AM
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
hokis
Aug 9, 2015 03:57 PM
