quick valve lash ?
Old Jun 11, 2006 | 07:45 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
quick valve lash ?
I installed my cam and heads today and when i set my lash it was VERY easy to give it the 3/4 turn after taking up the slack. Almost hand tight but the lifter was pushed down about 1/2 way. My ? is that this is normal for lifters that have not been pumped up. right?
Old Jun 11, 2006 | 08:07 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Try this site http://www.centuryperformance.com/valveadjustment.asp
Old Jun 12, 2006 | 12:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm guessing this isn't the stock style locking thread nuts? 'Cuz those are HARD to turn...
Old Jun 13, 2006 | 09:25 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
they are the poly locks that came with the roller rockers.
Old Jun 13, 2006 | 09:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, then yea. You're only fighting the lifter. I can push down on a pushrod and compress a lifter by hand, so with the mechanical advantage of the threads, it'll be easy.
Old Jun 13, 2006 | 09:40 PM
brutalform's Avatar
Yes. After you reach "zero" lash, give all the rocker nuts an additional 1/2 turn. Then, as you drive the car, they will be noisy, but should quiet up after the lifters get pressurized with oil. Sitting at idle will take longer.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
dimented24x7
Sep 6, 2015 03:51 PM
