AC A/C Compressor Clutch Removal ?
Old Jun 12, 2006 | 07:59 PM
BigPile2's Avatar
Car: 1991 Firebird
Engine: 305 TBI
Does any one have pictures on how to remove the AC compressor clutch? Or very, very detailed instructions on how to do it.
I am so confused and can't figure out what exactly I am supposed to be removing and the order stuff comes off. I got the bolt off that is in the center, but now nothing else comes off.
I am driving a 1991 Pontiac Firebird TBI 305.
Thanks in advance,
Rob
Old Jun 12, 2006 | 09:33 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Do you have a clutch puller?
Old Jun 12, 2006 | 10:46 PM
BigPile2's Avatar
Car: 1991 Firebird
Engine: 305 TBI
I have whole set of tools that I borrowed from a guy at work, but don't know how to use them or where to hook them too. Any pictures of the procedure? Thanks, Rob
Old Jun 12, 2006 | 11:15 PM
1981LT1's Avatar
Engine: LT1; LT1
I don't have any pics. But, pulling the pully and clutch is like pulling a harmonic balancer. You need the threaded portion that threads into the center where you removed the nut and then there is another screw that should thread into the center of that and then it pulls the pulley assy off.
Old Jun 12, 2006 | 11:28 PM
BigPile2's Avatar
Car: 1991 Firebird
Engine: 305 TBI
So I thread in the larger unit so that it grips into the outer threads, then screw in a smaller unit into the center of that....then what? If I get both of those threaded in, do I just pull?....is the entire pulley and everything supposed to come off...???
Thanks for your help, Rob
Old Jun 13, 2006 | 01:26 AM
1981LT1's Avatar
Engine: LT1; LT1
The pulley and clutch assembly will come off together. When you start to thread in the bolt, it will pull the assembly of the compressor shaft. when you get it off, the clutch plate, clutch coil, and pulley and bearing will come apart. Why are you replacing just the clutch? It is usually cheaper and easier to replace the entire compressor. Besides, you have to make sure you set the proper air gap on the the clutch plate when you put it back together. That is why most shops will replace the entire unit instead of trying to rebuild the old one. That's just my .02. Let me know if you need anything else.
TheExaminer
Aug 25, 2015 07:34 PM
zayne0
Aug 24, 2015 07:22 PM
3rdgenparts
Aug 8, 2015 07:09 PM
Thaney9
Aug 7, 2015 08:25 PM
