GM cylinder head questions
Old Jun 12, 2006 | 09:18 PM
greywuuf's Avatar
Car: '89 RS
Engine: 305 TBI (painfully stock)
Axle/Gears: 3.08
Can any one shed some light on these ?
price seems about right, and if I understand correctly they are allready set up for "big" valves
eBay Motors: CYLINDER HEADS VORTEC SB CHEVY ALUMINUM HY-FLOW *NEW* (item 8074077932 end time Jun-16-06 12:15:20 PDT)
I am considering going the RAM JET route on my pickup and if I like it I might move it to the RS, I figure I want a set of vortec heads anyway, might as well go Aluminum and if I can get the 2.02 valves all the better. I am wondering if these are a genuine GM part and if the were actually produced ready for the 2.02's or if they have been worked. Also is there some other machine work I wil need to make these ready ?(Aside from installing valve's/springs etc)
Dan
Old Jun 12, 2006 | 09:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I believe 2.0/1.55 was the biggest valves for a stock production casting, i may be wrong....
You may have to cut the spring pockets deeper depending on the springs you will be using.
Old Jun 12, 2006 | 10:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Those aren't the factory vortec heads. Vortecs tend to work better with the 1.94/1.6 combo I think.
They have been worked over in that department, I doubt any others.
You'd probably need to machine them, depending on the cam you use, tame cam, you're ok, large cam, need to machine guide bosses, and spring pockets I believe.
84z, how are you liking your vortech supercharger? *cough* poser *cough*
Old Jun 13, 2006 | 08:42 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Those I believe are more of the Pro Comp knockoff rip off heads. The company out of China that those piece of crap heads came from are avoided worse than the plague. I know of a member on another board who knows the owner of that company and how much of a con artist he is. I also have heard horror stories of those heads failing on engines.
http://www.fordmuscle.com/archives/2...rner/index.php
Old Jun 13, 2006 | 09:13 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
One day, one day. Just you wait and see
Actually my next motor might be a BBC. My buddy is getting lined up with a totally sick first gen with a 427, hes swapping it out for a 572 Then hes giving it either to me or we might stick it in my buddy's 87 chev 1/2 ton street truck.
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
