2.8 MFI problem
Old Jun 13, 2006 | 12:09 AM
1981z28owner's Avatar
2.8 MFI problem
we just bought a 86 camaro with the 2.8l mfi. It starts fin and idles ok, but the throttle responce is terrible. It will surge after about 2 seconds after stepping on the throttle, and it will keep reveving after you let off the throttle. Any help would be appreicated. i am used to carbs on 2nd gen camaros.
thanks
mike
Old Jun 13, 2006 | 07:42 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Check the idle air control valve (IAC) and throttle position sensor for proper operation. Idle speed is controlled mostly by the IAC position and fuel delivery by the ECM based on the TPS signal.
If both of these check out OK, check for vacuum leaks and emission hose routing.
Old Jun 13, 2006 | 08:51 AM
where are those located at? I am trying to find the book i have on 3r gen camaros.
Old Jun 13, 2006 | 09:19 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
They are both on the side of the throttle body, both held in place by two torx screws. The TPS has a 3-wire connector and the IAC has 4 wires. Do a search for "TPS adjustment" and "IAC".
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
andy74
Sep 3, 2015 08:41 AM
