engine break in oil
Old Jun 7, 2006 | 06:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
engine break in oil
I have been looking for some 30w NON DETERGANT oil to use in my new engine for its initial break in but I cant seem to find a 30w oil that is non detergant and recomended for new engines. The ones at autozone have detergants in them or is not then it says on the container "not for use on new or newly rebuilt engines or late model engines with hydraulic lifters". What can use guys?
Old Jun 7, 2006 | 06:58 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I just used el-cheapo mineral 10w30 on my break in's...
Changed it a few times in the first few days (why not, for $15 a change...) then after a week i dropped in the synthetic.
Old Jun 7, 2006 | 07:23 PM
ede's Avatar
ede
i wouldn't worry about it too much, there's lot more new or refreshed engines start up on detergent oil than not. buy some 30w and gm EOS or buy some shell rotella.
Old Jun 7, 2006 | 07:49 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
The paperwork that came with my new cam said to use rotella t. hopefully that will be sunday.
Old Jun 7, 2006 | 08:55 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Broken in 3 different engines on mineral oil and had no problems. Changed oil and filter after initial start up. Hot Rod magazine did a good article about flat tappet cams and oil compatibality last month-interesting to say the least. Might think about picking up a copy.
Old Jun 7, 2006 | 08:58 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Napa stocks the non detergent oil.
Old Jun 7, 2006 | 09:49 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I second Ede's reccomendation of Rotella,it clings to **** real well.
Old Jun 8, 2006 | 03:13 AM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
mineral oil?? never heard of that before! i guess it would work though!
Old Jun 12, 2006 | 02:14 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Theres no reason to use a non-detergent oil for break in. None.
I'm still in the process of breaking in my motor and am running Supertech HD-30. A straight 30 wt will be fine. Since I've already put 28 qts of oil in my motor it starts to add up. Since Supertech is made by the Mobil 1 people it works well.
Oil is full of a bunch of hype. Do some reasearch and you will find out moe than you ever wanted to know.
bobistheoilguy.com
EOS is good stuff to use as well. Its designed to be an assembly lubricant but for the initial break in it doesn't hurt anything. If you're running a flat tappet it gives a lot of the zinc cams need.
Old Jun 12, 2006 | 05:51 PM
BOTTLEDZ28's Avatar
Transmission: A4
well, Im just gonna stick with what I already have in the engine from priming it., Mobil 1 5w30. Ill add a bottle of EOS to it also
Old Jun 12, 2006 | 06:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
mobil 1? I thought mobil 1 is synthetic... (if they make a normal oil you're ok.)
I think I remember your previous thread about this, just wanted to make sure you're not using synthetic...
Old Jun 12, 2006 | 07:55 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Theres really nothing wrong with synthetic either, just the fact new motors usually get their oil changed a couple times in a short time period and Mobil 1 (or any other synthetic) is much more expensive.
What you have in there will be perfect. EOS can only help more, just don't go overboard with it.
Old Jun 12, 2006 | 08:10 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I was under the impression that synthetic can wipe cams and not let rings seat properly.
Sonix's Avatar
Car: 1982 Trans-Am
uhh, ok, either way, post back after the motor is broken in, and you've run it for a while. In this thread.
Old Jun 12, 2006 | 11:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Some say, depending on the hone job, the rings can seat themselves just by turning the motor over on the stand. I don't know if I believe all that but I've heard it many times over.
About synthetics for break in...I've still yet to find any hard proof that running a synthetic on break in can hurt a motor. Too much lubrication???
Now, also mentioning some stuff that Hot Rod wrote about when they did their article on cam break in and all the flat tappet cam failures in recent years; oil is starting to become very controlled. Emissions standards are making oil companys change their oil formulations which remove the necessary additives and minerals for proper cam break in. Thats why the GM EOS stuff is great to use on the initial startup and 500 mile OCI. Still don't have anything about synthetics specificially.
Why do you think Corvettes leave the factory with M1 (Mobil 1) from the beginning?
Old Jun 12, 2006 | 11:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
I remember reading a thread a little while ago, a guy posted asking why his cam went flat on break in, and he had followed procedure to a T, but used synthetic oil....
sorry CamaroRUS, I am mistaken, it is just the cam (flat tappet) to be worried about, not the rings. So on a roller cam, you're ok.
Fuzzy memory.
Old Jun 13, 2006 | 09:16 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
IIRC I read an artical in on of my magazines that synthetic can hurt flat tappet cams because it dosen't have enough zinc in it or somthing like that, sombody ells has to have that artical....I don't remember what magazine it was in...it had allot of good info though
Old Jun 13, 2006 | 09:40 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Some of the guys here recommend using shell rotella oil. Its supposed to still be loaded with zinc...
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
