Smoke on Shutoff!!
Old 06-13-2006, 07:40 PM
ruddiger52's Avatar
Car: 1983 Trans Am
Engine: V8 305 Crossfire
Smoke on Shutoff!!
Ok I bought this old 83 T/A 305 Crossfire for about 2k. High Miles. It cost me about 1400 just to get it to pass smog check in LA. It runs pretty well. Starts right up everytime. But now whenever I shut the car off the engine smokes for about 3 min and has a mild burning smell. The smoke seems to come from the back of the engine. It never smokes on start up or while driving. I do notice a smell while idling but no smoke until shut off. Is this engine close to being toast or what?? Any advice is much appreciated.
Old 06-13-2006, 07:44 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Valve cover gaskets, happens all the time with these cars, nothing major.
Old 06-13-2006, 07:49 PM
ruddiger52's Avatar
Car: 1983 Trans Am
Thank you Bandit84 I will check that out asap.
Old 06-13-2006, 07:52 PM
Car: 84' Trans Am
what tends to happen is the valve cover gaskets get worn out then a little oil splashes out the it burns off the side of the motor, it probaly smokes when it runs to but not as noticeable, like i said its not a real biggy. Mine does this too but im just going to leave it.
Old 06-14-2006, 02:07 PM
ruddiger52's Avatar
Car: 1983 Trans Am
Thanks man Ill probably get to it this weekend. I will post the results
Old 06-14-2006, 03:15 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Just to cement in the valve cover gasket answer, same here, except mine leaks down onto my exhaust.....argh, just been lazy about getting new covers.
Old 06-14-2006, 03:20 PM
nameinuse's Avatar
Same here,a little dribble from the left rear.
FormulasOnly
07-23-2018 08:47 AM
86White_T/A305
03-06-2016 01:48 PM
Badass355ciz28
09-28-2015 08:31 PM
KCG
09-23-2015 09:05 AM
Accerrito22
09-05-2015 09:34 PM
Quick Reply: Smoke on Shutoff!!
