Correct Aftermarket Starter?
Old Jun 13, 2006 | 10:33 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I'm buying the last few things I need from Summit, and I was planning on ordering a Summit Brand Mini Protorque Starter, but I just wanted to be sure this was the correct one.
Summit Protorque Mini Starter
It says for the Inline Bolt Pattern, which I believe is what I have. This is what the starter pad on my block looks like...
So this will work out for me right?
Old Jun 15, 2006 | 12:13 PM
Damon's Avatar
Your block is drilled for both starter bolt patterns- straight and staggered (like many GM blocks are). So you need the correct one for your flexplate/flywheel. If your is the 153 tooth you need the straight bolt pattern. If it's the larger 168 tooth you need a staggered bolt pattern starter.
Old Jun 15, 2006 | 05:07 PM
Starter says it will work for both, but only had inline bolt pattern, so hopefully I'll be fine
Thanks!
J-money
Jan 4, 2019 09:45 AM
Whata69
Mar 2, 2016 06:34 AM
383cam
Sep 9, 2015 06:01 AM
roysatikas
Sep 7, 2015 08:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
