Pre-ignition problems
Old Jun 15, 2006 | 06:22 PM
iroc z 88 114's Avatar
Car: 1988 iroc z
Engine: TPI 383
Transmission: 4 spd auto
My friend has an 87 Trans Am with the carbureted motor, I think lg4. When she shuts it off it keeps going real rough, I was told that it was pre-ignition. A mechanic gave me a can of internal engine cleaner to help it and after I did it the car does it even worse. Now I have searched all over and I can't find on this site or anywhere some things that can be done to figure out the problem or fix it. Right now I told her just to shut the car off in drive to stall it, but I would like to fix it. So if anyone knows anywhere there is some good info on it let me know. Thanks
-Sean
Old Jun 15, 2006 | 06:27 PM
ede's Avatar
ede
check your tune up, make sure it's good and the carb and timing are adjusted correctly
Old Jun 15, 2006 | 07:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes, make sure the timing isn't wayyy too far advanced.
pre-ignition will do that though. Try using a bit of water, through a vacuum line, keep revving the motor to keep it from dying, but give it a few ounces of water (slowly) through the vacuum lines. That internal engine cleaner does about the same thing....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
