Distributor help #1 spark plug???
Old Jun 17, 2006 | 10:53 PM
Ltrain925's Avatar
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i have an 85 T/A and i just put a 89 vette engine in it and me and my dad are at the time of starting it but we can't find out how you tell on the distributor where the #1 spark plug position is, it doesn't state it anywhere on the distributor with a number or a black top or anything there all the same, we got the car to start up and turn over but the timing is off and we might not have the wires set up right how can i tell which one it is thanks.
Old Jun 17, 2006 | 10:54 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
you can make it which ever one you want. Pull number one cylinder up on TDC and line the rotor up with one of the terminals. BAM, that's now your #1 position on the cap.
pull number 1 cylinder up on TDC and line the rotor up with one of the terminals on the cap. BAM, that's now your #1 terminal.
Old Jun 17, 2006 | 11:20 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It doesnt matter as long as the rotor points to the wire going to #1 while its at TDC and the rest are in sequence.
Old Jun 19, 2006 | 11:39 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THE PROBLEM IS TERMINAL
It’s the front left terminal.
(Newbies: left means drivers side)
Happy Racing!
If people drove any slower
they’d be going backwards.
Old Jun 19, 2006 | 06:41 PM
Dialed_In's Avatar
Originally Posted by NINÅ
[CENTER]
doesn't have to be
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
