Starter heat soak problem
Old Jun 19, 2006 | 09:45 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Hey all, I have a 92 Z28 with a built up Miniram'ed 383 with shorty headers and a LT1 starter. Im wondering what you guys suggest for a insulator on my starter? Should I go with a heat shield, or wrap the starter with some reflective Mylar? Thanks in advance.
Old Jun 19, 2006 | 09:54 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
heat shield will be fine.
Old Jun 19, 2006 | 10:03 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Just finished fixing my hot start problem. Used both the Thermotec Wrap and also a Mr Gasket heat shield. Replaced the starter with a new reman.
Funny, a starter motor for a 1969 Chevelle 350 was $119(can) yet a heavy duty starter for a 1969 427ci Bigblock Corvette was only $89 (can)
Took the BBC starter and just swapped nose cones.
Seems to start fine now. required a few mods with a crow bar to ensure there was a "Air Gap" between the heat shield and header tubes. They are very close to the starter.
The positive starter cable was also corroded for sitting all winter.
You can check your starter cable for resistance by reading the voltage off the starter solenoid to ground with a volt meter, while cranking over the starter. Should be 9.5V or better.
Old Jun 19, 2006 | 11:04 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I'd spend the 15$ just to be sure. Alot of guys will probably comment on how heat sink in starters is a myth, but I believe it seeing as that I had a starter a year ago that wouldnt budge after driving in hot weather, but after you cooled down 30 minutes later, it kicked right over...like clockwork.
Either way, you'd only end up paying 15$ for an AC Delco one, but I'd rather not have to keep replacing them.
Old Jun 20, 2006 | 07:53 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the shield that goes around the selinoid is all I use and I use a stock autozone starter and headers
I have not had one problem with startups
Old Jun 20, 2006 | 03:52 PM
Randy92Z's Avatar
Engine: Miniram 383
GuitarJunki17, spend $15 on what? Im not sure what your talking about. Thanks.
Old Jun 21, 2006 | 12:36 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
How about ceramic coating? Just a thought.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
92camaroJoe
Aug 13, 2015 06:07 AM
