Harmonic balancer and flywheel
Old Jun 20, 2006 | 12:55 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Hey, I have heard many people with conflicting stories about these two. I know the operation of both, but my question is that I pulled off a flywheel from a 91RS (manual tranny) and need to know if the flywheel and balancer need to be matched. Don't want to have vibrations when its first started or bearings going out suddenly. What I am saying is that do these need to be a matched set or how to go about checking it? Not sure how many teeth on the flywheel, been too busy to count that high...
Thanks.
Old Jun 20, 2006 | 01:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, they're not matched.
The only time you'd have to worry about it would be if it was rebuilt and the machinist balanced the assembly by altering the flywheel or balancer.
Old Jun 20, 2006 | 01:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
they *should* be all neutral balanced. The balancing for 305/350 is internal so any balancer/flywheel should do the trick as long as its not off of a 400.
Old Jun 20, 2006 | 04:56 PM
I figured as much, being both came off a 1 piece seal motor shouldnt have a problem, just doesnt hurt to ask. Thanks.
Old Jun 20, 2006 | 08:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll just need to match the starter to the flywheel.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
