a/c leakage problem.
Old Jun 20, 2006 | 07:44 PM
SoCo80p's Avatar
my a/c hasen't worked since i bought the car (87' 2.8) and with it being so hot out i decided it's time to fix it and convert to r134a. the system was completly empty so i added just one can as the kit said and heard no leaks and it's holding pressure so i went and filled the system still holding pressue. the air blows somewhat cold, but not as cold as it should. i also noticed after i turn the car off a hissing noise (leak i'm sure) coming from inside of the box on the firewall (heater core area?) where one line from the evaporater goes in. it hisses for about 5 seconds then goes away. i'm wondering if anyone knows what the problem might be or how to fix it.
Old Jun 20, 2006 | 08:11 PM
Damon's Avatar
You probably still don't have enough in it.
When it's working correctly the compressor should be engaged almost 100% of the time at idle on a hot day.
Those little cans of 134 can take FOREVER to drain into the A/C system. 20-30 minutes per can not being uncommon in my experience. When it's all in there the can will be truly "empty" and light as a feather. First time I did this I was impatient and couldn't beleive how long it would take to drain a full can of 134 into the system. I probably gave up about 1/2 way through the can, wasting the rest. I always add it while the engine and A/C are running (I beleive that is the recommended procedure).
I have found laying the can on top of something hot (intake manifold) while charging helps speed the process somewhat. But it will still take a REAL long time for each can. Be patient, grasshopper!
A few seconds of hissing when you turn the car off is perfectly normal. Pressures still have to equalize between the high pressure and low pressure sides of the A/C system
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
