now that i found it help be get it off
Old Jun 21, 2006 | 08:46 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
now that i found the oil pressure sending unit how do you get it off. my is all oil soaked and i cant see how you get it off and tips will be good .
Old Jun 21, 2006 | 11:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It should be threaded in. Turn it gently. It's soft brass I think, so don't shear it off. PB blaster or something shouldn't be needed, as the threads should be oiled. You could heat it up with a torch if you wanted.
Old Jun 21, 2006 | 11:35 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
i dont know as if a torch on an oil soaked motor would be a good idea...
Can you holler FIRE!?!?!
That said, you should be able to spin it off by hand. If not their is a hex on the back side of the sending unit (facing the block) that you can use a wrench on.
Old Jun 21, 2006 | 11:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh wow, I better go to bed now...
Old Jun 22, 2006 | 12:05 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
haha, well hopefully if he fired up the torch and crawled in there he would have said this doesnt look too good!
But ya never know, people burn down their cars all the time
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Abubaca
Nov 5, 2016 12:22 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
rudolphschenker
Sep 4, 2015 02:41 AM
