How to check ignition system
Old Jun 22, 2006 | 06:58 PM
Tmoney04's Avatar
How do I test and ensure that I am getting spark to each plug starting from square 1. how do I test ignition module, distributor,coil,plugs?
Old Jun 23, 2006 | 12:09 PM
Tmoney04's Avatar
Anybody? If you could just direct me to some info.
Old Jun 23, 2006 | 07:05 PM
92v6bird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1 liter
Transmission: 5 speed manual
do a spark test
Get an insulated screw driver and stick it in the plug wire and hold the screwdriver about 1/4 in. away from the block, or any unpainted surface, and crank the engine. Normal spark should occur. make sure you don't hold the wire while doing this, use spark plug wire pullers that are insulated or hold the insulated part of the screwdriver. also make sure you don't do this test around fuel injectors or anywhere where fuel might be present.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
Fast355
Dec 2, 2016 06:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
