rod knock
Old Jun 4, 2006 | 11:15 AM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 5 speed
rod knock
well i know i got a problem but the bigger one is not much money! so im going to have to drive on this for a while what should i do? im not plannning on fixing cuz its just a 305 but i dont have the money for a cheap 350 either so is there anything i can do just make this motor last a lil longer thanks
Old Jun 4, 2006 | 11:24 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Nothing guaranteed...just drive it as little and easy as possible. It could blow at idle in the driveway one morning or wait months. Just plan on saving as much as quickly as possible to get it taken care of before it does decide to go. I had a front main spun on my 305 that I drove about 300 miles on the interstate and it made it. Didint know it was a spun main, thought it was a rod, but its one of those things that you cant really say for sure how long it will last. The only way to be sure it will go a certain length of time is to not drive it or replace it. So just be easy on it and drive it as little as possible.
Old Jun 4, 2006 | 09:23 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
i had someone say my rod knock sounds like a rocker arm or something along those lines is off. maybe im wrong but what does a rod knock sound like, my car has more of a ticking sound ill try to get a clip up somehow. thanks for the help
Old Jun 4, 2006 | 09:40 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
my car - Google Video
you can kind of hear it and it stoped that lil bit of somking, also sorry of the the quality its taken with a digital camra
Old Jun 4, 2006 | 10:09 PM
Car: '87 Trans-Am
Its kind of hard to tell, but it sounds pretty loud to me. More like a knock than a tick. If it comes and goes though, it probably isnt a rod...maybe a main or possibly lifter. Either way, the previous advice still stands. Drive as little and easy as possible until you nail it down or get time/money to fix it.
Old Jun 5, 2006 | 02:05 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
i asked my auto teacher and he said it sounds like either the timing chain or maybe the water pump if im really lucky, the sound does seem like its coming from the center of the engine also if it is the timing chain or water pump would after market be worth it also would it ever be interchangeable between a 350
Old Jun 6, 2006 | 11:14 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
This is what a rod knock sounds like:
http://www.zieglerdigital.ca/public/...stepper-01.mpg
http://www.zieglerdigital.ca/public/...stepper-02.mpg
That 350 was replaced to say the least, lol
Old Jun 6, 2006 | 08:35 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
allright so its my timing chain and i was wondering what else im going to need things like gaskets, i think i just need the water pump and the timing cover gaskets but is there anything else?
Old Jun 7, 2006 | 07:09 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
will somone please help me asap i was just wondering do i really have to take my oil pan off to take the timing cover off! thanks ahead of time
Old Jun 7, 2006 | 07:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes - you have to remove the oil pan - but not entirely. You can get the car on stands (or a lift, and jack up on the motor just enough to remove the motor mount bolts on each side, then jack slightly more - just enough to get the oil pan gasket in/out (sometimes you can get lucky and not have to remove the motor mount bolts, but don't count on it). You can jack slightly more, and get the pan out altogether if needed. But there will have to be some raising of the motor in order to get the pan to clear the subframe - even enough to just get the gasket in correctly.
Put in a double roller chain while there, they are only $10 more) and make sure you get it indexed properly (dots on gearset aligned to each other).
Old Jun 8, 2006 | 04:49 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
k it doesnt seem like its the timing chain but before i put everything back together whats the the length of the chain?
Old Jun 8, 2006 | 05:19 PM
EvilCartman's Avatar
Car: '82 Z28
Water pump or timing chain? wtf? I know things are a little more difficult to diagnose over the internet but that sounds like a loose rocker to me. Possibly one of the rocker studs has pulled out of the head a bit. Timing chain length, not sure but it shouldn't be really sloppy on a decent old one.
Old Jun 8, 2006 | 05:59 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
More often then not the tensioners get old and sloppy. When my tenioner let go on my 94 s10, the chain slapping around sounded exactly like the clip he posted. You couldnt tell that the tensioner was gone to look at it either. I hope that ends up being your problem.
Old Jun 8, 2006 | 08:48 PM
Car: '82 Z28
Last time I checked, there is no timing chain tensioner on a stock sbc.
Old Jun 9, 2006 | 07:43 PM
Car: 1992 RS
Engine: Carbed 350
Seems to me that, the diagnosis is changing depending on the difficulty of the repair necessary. Timing chain, but not after info that the pan had to be dropped?
The problem needs properly diagnosed based on reality, fact, and some automotive sense (not on the difficulty of possible repairs), then repaired and put to rest.
Old Jun 9, 2006 | 08:46 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Take it somewhere and have someone look at it that knows what they're talking about. Timing chains don't make a ticking or knocking noise. They stretch, but that won't do anything except screw up your valve timing. And they certainly don't have a tensioner OH:
Old Jun 9, 2006 | 10:45 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Did anybody else notice the grind/zzzzz sound when the engine was shut off?
Old Jun 10, 2006 | 12:47 AM
Car: '82 Z28
Yup, kinda sounded like the serp belt to me. Some Dodge diesels make a noise a lot like that when they come to a stop.
Old Jun 10, 2006 | 06:30 AM
Toehead's Avatar
I've got v-6 on the brain!
Old Jun 10, 2006 | 06:03 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
k i got the problem solve it was just one of the rockers but to explain it losing all of its power (after the clip) the thing that hooks up to the right injecter was halfway off and the clip that holds it down is broken so yeah i guess in the end it was just a learning experience
Old Jun 10, 2006 | 08:32 PM
Car: '82 Z28
Yay I was right, a loose rocker Rocker stud look ok?
Old Jun 11, 2006 | 04:41 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
yeah it looked fine but can somone explain how that happens? so maybe i can avoide it later also found out my brother put a set of roller rockers on it before he sold to me so i aint complaining
Old Jun 23, 2006 | 07:25 PM
92v6bird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1 liter
Transmission: 5 speed manual
my car sounds exactly like yours. everyone was telling me it was an exhaust leak but i had my exhaust checked out and it was fine. I had a feeling it was something to do with the valvetrain.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
