Brodix or Vortec?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Brodix or Vortec?
Don't wanna take up all your time here, so I'll make this fast.
I was planning on buying Brodix IK200 aluminum heads for $1000.
200cc Intake ports
64cc Combustion Chambers
1.470'' Dual Valve Springs
(125 lbs. Closed / 325 lbs. Open).575'' Max lift
2.02''/1.60'' Valves
Straight Plug
Assemble
Friend of mine wants to sell me his Vortec heads from Pro Topline. They are Iron. He wants 600$ for them.
170cc intake runners
1.94/1.5 valves
120lbs closed, 275lbs open springs, good for .540 lift
What deal here would be a better deal? Will brodix really make that much more power to where it would be worth 400$ more? Keep in mind that if I do the vortecs I might be able to go with a new TPI baseplate from edelbrock.
Thanks!
_Clark
200cc Intake ports
Straight Plug
Assemble
1.94/1.5 valves
Thanks!
_Clark
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
well I'd defenatly go whith the Brodix heads...they are arguably the best out there, and the power they will make compared to the vortec heads is amazing, esp. if U go W/ a big cam
Keep this in mind too: The cam I am going with is .452/.465 lift and 214/220 duration. It's a CompuCam from Cranecams. Also, I think he is throwing in a set of 1.52 Comp Cams roller rockers...still have to clear that up though.
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
With that small of a cam I would go with the vortec heads. Although I would try and talk him down in price because someone I know got a complete assembled pair of Topline Vortec heads for $550 shipped to his door and they werent second hand. The heads also had some minor cleanup done to them. Remember Topline went out of bussiness so if you have any problems or need a replacement a matching head will be harder to find. Not sure of the difference of the RHS head but they are a bit pricier.
Car: '88 IROC-Z medium orange metallic
Save up a few more bucks and buy a better head. Even the IK200's are a budget head, lower than the Race Rites.. The stud bosses are kinda weak, decks aren't very thick, heavy valves and the ports aren't that much better than what you'll find in those vortecs. Between those two heads, I would get the Brodix still because you'll have the advantages of an aluminum head. I would, however, save up a couple more bucks and get a set of Race Rite heads. They're the least I would put on a performance motor. They've got a little better vavles, chambers are much better and so are the ports. They've got thicker decks and the heads are just a lot stronger. They've also got angle plugs
Car: 71 Nova
Why would you suggest 200 cc port heads especially with that cam in a 350. I would think the port velocity would be ****. I can tell you the those vortec heads are at least good for 12.44 @ 106.81MPH since thats what one of the guys with a 357 is pulling now.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Pick up the new Chevy High Performance and read the head test they do in there...you might be surprised. Their budget is $1000 for heads and they test 8 of them...
HTH.
HTH.
Because I didn't see where he mentioned what cam he was using. 12.40's in a 3600 lb TPI car with that cam? Nuh uh. Especially not with 2.73's and you know he's got the stock converter.
Car: 71 Nova
No the car is definately not TPI. Hes running a carb and the weight is pretty close. Not saying he shouldnt get different heads but he suggested that cam. Yeah he is also running a 3.73 gear with a TH350. But trap speeds are a very good indication of hp. Funny thing this is his second attempt at the track since he just slapped these heads on like a couple months ago. He still trying to dial everything in.
HTH.
HTH.
Also, and I should have mentioned this before. This car is my daily driver that I will be using on the street everyday. I honestly don't want to pay $400 more for 50lbs shaved off, and maybe 5hp. I plugged in both setups to DD to the T, and saw a gain with Brodix of 6hp. Even with a stealth ram setup, I see the same gains. Now, I know that DD isn't the most accurate program, but it's giving me an idea of what I will be seeing.
And I was also thinking that with 200cc intake runners, it would be too much for the cam I am running, which is why I think 170cc might be more suiting.
But the only thing that is making me shy away is the fact that I will need to shell out 400$ more for a vortec baseplate, breaking me even of where I would be if I just got Brodix heads.
Any more input here?
Originally Posted by ME Leigh
So your running a tpi?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd keep your stock heads then and port them up. Going to vortecs with TPI makes no sense, you need a new base. Also TPI can't support big heads so you need something aroundd 170-180 cc's. I'd look for something else. Try some dart iron eagles or some RHS heads.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If I was going to go with vortecs, (They work very well and are a good match to what you have and are trying to achieve) I would not invest $400 in a TPI (vortec base). I would buy a "RamJet" intake manifold. Like the intake used on GM's 350 ramjet crate motor. Then you'd see what the vortecs can really do.
The stock long tube small runner TPI intake manifold is the choke point in the system on your car. If you want to run the stock runners, I would port the stock heads (YOURSELF) and put in larger valves. These heads will flow plenty (much more than you need) when ported. And end up with more velocity than the 200cc heads. You'll get the most bang for the $$$'s.
You could port your heads. You could get another set of 350TPI heads to port. You could get a set of 305 TPI heads to port and install larger valves. They all have the same power potential once you're all done. (305 TPI heads (081) can be had for a song).
This can be done for much less than either a vortec swap or buying new aluminum heads.
Car: 71 Nova
I know you guys like doing the home porting thing but from what im told you really need a flow bench to get this right. I mean the simplest things you do can make turbulence in the ports and you wont really know till you have a flow bench to hear the difference. I know you can get them to perform better but a flow bench would really make the porting worth while. This is pretty damn interesting though. I have seen someone get 250 cfm at .500 with World S/R heads with mild porting. These heads as cast couldnt even break the 200 cfm barrier. I think he said he would have eneded up at about 230 if it wasnt for the flow bench since it helped get rid of any turbulence.
http://www.performancetrends.com/ez_flow_system.htm
Car: 71 Nova
Heres the new times with the topline vortec heads i mentioned before. hes starting to dial them in well. Just trying to give the potential for the topline/RHS vortec heads. This is a carbed application though.
357ci/TH350, 8.5" 3.73
60' 1.67
7.74 @ 87.75
12.26 @ 108.29
60' 1.67
7.74 @ 87.75
12.26 @ 108.29
Nice numbers...the Brodix heads are in the mail though =). I would have gone Vortec, but I would have had to adapt to a vortec baseplate...which would have put me even with just getting Brodix heads. At least now I can get an LT1 or HSR in the future, I have somewhere to expand you know?
Car: 71 Nova
Originally Posted by GuitarJunki17
Nice numbers...
Car: 71 Nova
BTW this is the new times with the topline vortec heads. I would say thats pretty impressive for some bolt on vortecs for $550.
60' 1.66
7.63 @ 88.66
12.10 @ 109.35
60' 1.66
7.63 @ 88.66
12.10 @ 109.35
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
yeee haaa!!!
check out the aug 06 issue of chevy high performance. tested on 383 heads from aerohead racing, edlebrock performer, scroggin vortec, rhs lightening, competition products, trick flow, world motown and dart.
no doubt about it vortecs are hard to beat. check it out........
tq hp
aerohead 440 389
edlebrk 458 405
vortec 445 392
rhs 432 381
comptn 428 377
trick flo 428 377
wrld motn 445 393
dart 447 396
all the heads were more expensive than the vortecs. most by about
$300. heck and for $300 you can have a little work done to em.
hope this helps your decision.
tq hp
aerohead 440 389
edlebrk 458 405
vortec 445 392
rhs 432 381
comptn 428 377
trick flo 428 377
wrld motn 445 393
dart 447 396
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
tq hp
aerohead 440 389
edlebrk 458 405
vortec 445 392
rhs 432 381
comptn 428 377
trick flo 428 377
wrld motn 445 393
dart 447 396
tq hp
aerohead 440 389
edlebrk 458 405
vortec 445 392
rhs 432 381
comptn 428 377
trick flo 428 377
wrld motn 445 393
dart 447 396
The Vortecs they used for that test were the "upgraded" heads from Scoggin-Dickey which cost $680.
The only real disadvantage the Iron Eagles suffered from was 73cc combustion chambers which kept the compression down a little more than the other heads.
Just trying to keep the information accurate.
BTW, those Edelbrock RPM heads kicked butt!!
I was pleasantly surprised, to say the least. Junior Member
Car: 87Z
Engine: top secret
Transmission: top secret
those were actually the dart iron eagle 215cc. I wish the 165cc made that power. I have a set of used 165's and if you think that they made that much power I will sell them to you. And by the way those were average power and torque figures. Those darts were also 65cc combustion chambers.
Dart Cylinder Heads
Dart Cylinder Heads
No. Read the article again. They measured the intake runners, the combustion chambers and the exhaust ports themselves.
And yes, those were average numbers, which mean a lot more than peak numbers do when the engine is in the car.
Those are Iron Eagles with 165 cc intake runners.
Here's the special at Aerohead Racing.
Car: 87Z
Engine: top secret
I just read the tech article online. Look at it here. Dart Cylinder Heads They are not the 165s
Originally Posted by AJ_92RS
All the heads where more expensive than the Vortecs other than the Aerohead Racing heads. Those are actually Dart 165cc Iron Eagles for $625.
Originally Posted by CHP Magazine
One of the bargains we tested was the Aerohead small-block Chevy head, featuring a larger com-bustion chamber than most tested. It should be noted that this netted a lower compression ratio. These reconditioned Dart Iron Eagle S/S heads produced a healthy torque number of 475 lb-ft at 3,900 rpm and 430 horses at 5,700 rpm. With these heads you can gain power and save money.
I'll give you $50 for them.
oops, sry for the error. it was very late, no excuses though. thanks for the correction.
Truth be known, I'd rather have the Brodix IK180 heads.
Car: 87Z
Engine: top secret
oh, now i see. sorry for the mistake. did arrowhead do any porting to these castings? Are they reconditioned with undercut valves? Interesting....I like what I see. No I will not sell them for $50 now. I only paid $385 for them.
Car: 87Z
Engine: top secret
I called aerohead (they are here in Indiana actually) and those are Dart S/S straight out of the box brand new. The reconditioned was a misprint.With some porting and undercut valves it seems these heads might be keepers. Any cam suggestions for running on a 383 TPI? They have the XE274 in the test but that seems a bit much for the LTR.
Chas91Z28
Oct 22, 2015 10:12 AM
redformula88
Oct 14, 2015 06:08 PM
monte87cortez
Sep 26, 2015 08:10 PM
