Low WOT TPS Voltage
Old Jun 25, 2006 | 12:32 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Low WOT TPS Voltage
My closed TPS is fine, my WOT is only 3v. The pattern when opening the throttle is smooth and linear. I can change my WOT setting in the C950, but my question is.... is my TPS going bad? Bad already? or just a weird fluke that will be fine after I tell the ECM what WOT is?
-Paul
Old Jun 25, 2006 | 02:25 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
You know..my TPS voltage was the same..but mine wouldnt go over 4 volts.I replaced it and rechecked it and did the same thing.So I was thinking maybe the throttle cable was stretching..Closed is about .5 and WOT is around 4.50 I think thats roughly for every TPS.If I mash the pedal into the floor board it will go higher but not much.
Old Jun 25, 2006 | 10:33 PM
What about when you open the throttle blades 100% by hand? What does it read then?
Old Jun 25, 2006 | 11:31 PM
jstrdn90rs's Avatar
Good idea...I think it was the same ,but looks like tomorrow I will be checking that.I havent checked it with the new TPS in it..so cool thanks for that info.Then that would give me a better idea on the cable.
db057
Apr 28, 2019 07:45 AM
BumpaD82
Feb 26, 2016 02:57 PM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
