Cylinder heads preference
Old Jun 25, 2006 | 02:03 PM
Justin86camaro's Avatar
Car: 86 Camaro
Engine: 350, aluminum heads, carb
Transmission: TH-700R4
Axle/Gears: 7.5 10 bolt, 3.42:1
hey guys, i'm looking to buy a set of cylinder heads for my 350 sb ive kinda narrowed it down the trickflow aluminum and the edelbrock rpm aluminum. just wanted to know who has had success with your choice in head. thanks for the input.
Old Jun 25, 2006 | 02:12 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Pertty vague. Which specific models are you considering and what is the general setup.
Further, why have you narrowed it to only these two manufcaturers?
Old Jun 25, 2006 | 03:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'm with Trevor... you are too vauge for us to give you a good answer. Whats been done to your 350? What do you want it to do? Daily driver? Race car? Why have you narrowed it down to those two, and ditched (for example) AFR, GM Perf Parts, World...?
Old Jun 25, 2006 | 11:49 PM
Car: 86 Camaro
its in my 86 camaro flat top hyperpnuematic pistons 9.5:1 with 64cc heads. its a street car that is a daily driver but also i want some power. its got a small cam, aluminum intake and 750 carb. i was looking into going vortec but decided to keep it original and stay with the conventional design. i've heard nothing but good things from people with the trick flow and edelbrock heads. i like the trick flow heads alot but just wanted some input from other people.
Old Jun 26, 2006 | 12:49 AM
11 Flat's Avatar
trickflow is the better of the 2 heads
Old Jun 26, 2006 | 09:44 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
If your keeping a small cam, say under .470 of lift, I'd go vortec. Real cheap and about the same amount of power, sometimes more, under 5k rpms as "expensive heads". If you think you might really build this motor up sometime in the relatively near future, trick flow.
Old Jun 26, 2006 | 10:01 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I agree that the smaller trick flows are far superior to the likes of the RPM head. What is your budget for heads?
Old Jun 26, 2006 | 11:20 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I was looking into this myself. A friend of mine got the Kenny Dutweiler Trickflows, and I was going to do the same because he was happy, and they are the cheapest aluminums in their class. Well, I recently found out that Brodix makes an aluminum head called the IK200 that outflows the Trickflow heads. The IK200's dropped their price to $999.00 to compete with Trick, who have since dropped their heads down to $975.00. IMO, the extra flow would be worth that 25$ more. You can find the heads from Brodix at Jegs.
Old Jun 26, 2006 | 11:39 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The only thing with the IK200 is its a 200cc port and for a small cam 350 it may not be the best match. Remember its about getting the best flow through the smallest port.
Hydraulic roller 234/238@.050 .574/.584 w/Comp 1.6 rockers.
For example in the Super Chevy's "Danger Mouse" series with this cam they did the e-tec 200's, then the e-tec 170's, and then the Brodix RR180's. All with the same cam but different intakes and the 170's beat them all. The motor was a 355. Raw flow numbers can be highly deceptive when it comes down to performance.
The e-tec 170 heads made 485hp and 456lbs of torque.
Old Jun 26, 2006 | 01:49 PM
Car: 86 Camaro
I'VE READ THAT SAME ISSUE I. I LIKE THE TRICK FLOW HEADS ALOT BUT THE ONLY CATCH FOR ME IS THAT I PUT ON A SET OF HEADERS THAT I WILL NEED TO SWAP IF I USE THE TRICK FLOWS DUE TO THE D SHAPE EXHAUST PORT.
Chuck84TA
Jul 15, 2016 09:05 PM
ydnar417
Sep 23, 2015 05:57 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
